How to check CUBE version in router?
adil.nasser3
Level 4
Level 4
What is the command to show the version of CUBE software running an IOS voice router?
Adil
Leo, your link seems to take us into infinite loop 😞
Adil, issue "sh version" which will give you the IOS version on the router, which is what most people go by, if you need to cross-reference that to CUBE version then I belive it is the same as CME version, which this matrix will provide:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
HTH,
Chris
Leo Laohoo
HTH,
Chris
Sorry.  Wanted to let everyone know the different links.  If I don't put the link to the other one ...
Thank you Chris.
