02-11-2020 01:36 AM
Hi all there
Is there any way to count the number of calls goes outside via PSTN in the last month or something like this.
is RTMT do that? and how to do that?
Thanks in advance.
02-11-2020 04:59 AM
Hello Abu
RTMT does not have any data storage repository for calls, it can provide you real time view of calls going in cluster.
For historical calls, you need to setup a CDR/Billing server which will help you to store the call records.
Take a look on CDR server functionality and setup :
Rate if you find this helpful
02-11-2020 07:50 AM
02-15-2020 05:34 AM
Thanks, Mr. Mohammad. But when I enabled That services this message comes out: (( 30061 : Data is not available in the Database.))
what can I do for this?
Thanks in Advance...
02-15-2020 07:16 AM
CDR only starts producing data after it is enabled, if you just enabled it, you will only have data from that point forward.
