how to config 7942G support VPN
bo liu
Level 4
Level 4
my CUCM is 8.5
now i know 7942G support SSL VPN client
everyone can tell me how to config the phone use VPN
our custormer need this feature ....thanks very much
Jaime Valencia
Cisco Unified Communications Manager Security Guide, Release 8.5(1)
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/security/8_5_1/secugd/sec-851-cm.html
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
java
java
thanks for you reply
