09-10-2012 10:33 AM - edited 03-16-2019 01:07 PM
I'm trying to set up one of our receptionist lines to roll over to another line if the receptionist doesnt answer. I beleive I have things configured correctly, but it doesnt appear to work. Here is a screen shot from within Call Manager. Do I have something ticked wrong? I have confirmed that that search space does contain this directory number that I am trying to forward to.
John
Solved! Go to Solution.
09-10-2012 10:39 AM
Hi John,
Just un-check the voicemail check boxes and you should be good to
Cheers!
Rob
"Why not help one another on the way" - Bob Marley
09-10-2012 10:39 AM
Hi John,
Cheers!
Rob
09-10-2012 01:56 PM
Thanks Rob. That definitley did it. Since godaddy.com is down, I didnt get an email from this forum. I'm glad I decided to check in. Thank you very much for your help.
08-24-2017 12:17 AM
Even I am facing similar issue, unchecked voicemail box but no luck. Call Forward no answer does not work. Please help.
Thank you
08-31-2017 01:12 PM
Worked for me as well. Thanks!
