How to configure CMR in Gateway
According to the link
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/service/7_1_2/cdrdef/cdradmin/cdrcallinfo.html we can take two fields as common between Gateway CMR and call manager CDR. globalCallID_callManagerId and globalCallId_callId.
How to configure cisco ios gateway to generate CMR?
Actually I am trying to get the globalCallId_callId from CMR of gateway to map globalCallId_callId from CDR of CUCM.
Pandian
2 Accepted Solutions
Manish Gogna
Hi Pandian,
For CDR config on the ios gateways the following document is followed
http://www.cisco.com/c/en/us/td/docs/ios/voice/cdr/developer/guide/cdrdev/cdrcsv.html
It does not mention anything separately about cmr but the cdr configuration will need to be done as per the above.
Manish
Hi Pandian,
Yes, that's what i could make out from the available documentation and guides. If someone knows a way to configure the cmr on gateways using any Cisco or third party solution they can reply to this post.
Manish
Manish Gogna
Hi Pandian,
Manish
Thanks Manish,
To clarify, only CDR can be generated from gateways and not the CMRs correct?
-Pandian
Hi Pandian,
Manish
Thanks a lot Manish...
