How to configure conference setup in CME
m.sajidhussain
Can you  please inform that how can i configure conference setup in our Call Manager Express 10.5
We have SCCP & SIP phones and required conference setup
Waiting for your earliest replies will be highly appreciated
Thank you
Sajid
Suresh Hudda
Hi Sajid,
Just you need to configure hw conference profile and mention it under telephony-service.
You may refer below link for detailed & tested config.
https://supportforums.cisco.com/discussion/12748366/cme-conference-does-not-works
Suresh
Jaime Valencia
Have you reviewed the CME configuration guide which has all that info??
If not, that should have been your first step
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmeconf.html
java
if this helps, please rate
Thanks, Jamie! You've helped my coworkers and me so much over the years.
Nadeem Ahmed
You need to make sure one thing that you have enough DSP(PVDM) to configure conference or use HW resources from GW.
Rest you can follow doc shared by Java which is very good and explain in detailed.
Br,
nadeem
Br, Nadeem Please rate all useful post.
