Hi !
How to configure CUCM and H323 Gateway to dial " #22# through CUCM and H323 gateway. . I have created
dial-Pattern in Call Manager for #22# . But CUCM is striping last #. So users can not dial #22# to PSTN. The call
flow is IP Phone ---> CUCM ---> H323GW ---> PSTN Line. I have created Dial-pattern in CUCM for #22# but
it stripe last # and sendong only #22 . Can you please sugget how we can configure CUCM to forward # at the end the dialed string ? I have already changed in Server Parameter as " Strip # Sign from Called Party Number False " . But
in reality it not working. CM is still strip # at the end of the dialed strings.
