01-07-2012 10:54 PM - edited 03-16-2019 08:52 AM
The hotline is like emergency phone with no keypad, and shall be connected to an identical phone automatically when it's placed in an off-hook condition?
seems very easy but i donot know where to configure this.
Thanks!
Solved! Go to Solution.
01-08-2012 06:58 AM
Hi there,
The step by step directions in this guide are very good (the principles should carry over nicely)
Hotdial on IP Phones with CallManager Configuration Example
Cheers!
Rob
01-08-2012 06:58 AM
Hi there,
Cheers!
Rob
01-10-2012 05:03 PM
Thanks Rob, good example and i think it also work in CUCM 8.5.
09-02-2014 10:36 PM
Hotline is a little different from PLAR -
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/8_0_2/ccmfeat/fsgd-802-cm/fshotline.html
hotline was introduced in 8.0 and is different from plar in that:
The hotline feature adds the additional restriction that hotline devices that receive calls will only receive calls from other hotline devices, and will reject non-hotline callers.
Hotline != Hotdial
11-01-2014 04:01 AM
Hotdial is PLAR
But Hotline is different .
We need please HotLine configuration steps.
