10-27-2013 12:58 PM - edited 03-16-2019 08:05 PM
I have a CME with several cisco phones and 1 SIP TSP. SIP trunk is registered and calls are coming in and out, but the thing is that only 1 active call can be made. If one is active second call cannot be made. I contacted our TSP, they have asterisk on their side and they said that if I want to use more channels I have make more registers with different usernames. Router model is 2900 with universal IOS 15.2. this is the old config of sip-ua :
sip-ua
credentials username xxxxxxxxxxx password 7 0xxxxxxxxxxxxxxxxx realm xxxxxxxxxxxxxxxx
authentication username xxxxxxxxxxxxxxxxx password 7 xxxxxxxxxxxxxxxxxxxxxx
no remote-party-id
max-forwards 15
registrar ipv4:xxxxxxxxxxxxx expires 600
host-registrar
and this is the new one:
sip-ua
credentials username xxxxxxxxxxxx password 7 xxxxxxxxxxxxxxxxx realm xxxxxxxxxxxxx
authentication username xxxxxxxxxx password 7 xxxxxxxxxxxxxxxxx
no remote-party-id
max-forwards 15
registrar 1 ipv4:xxxxxxxxxxxxx expires 600
registrar 2 ipv4:xxxxxxxxxxxxx expires 600
host-registrar
actually the realms and registar-s are the same IP addresses, passwords are also the same, only difference is in username. The thing is that I cannot enter new authentiation parameters, when I enter the new one it replaces the old one.
and this is the register status :
show sip-ua register status
--------------------- Registrar-Index 1 ---------------------
Line peer expires(sec) registered P-Associ-URI
9954932203300 20002 64 yes
9954932203301 -1 64 no
--------------------- Registrar-Index 2 ---------------------
9954932203300 20002 68 yes
9954932203301 -1 68 no
as you can see second username cannot register.
So I have 2 questions:
1) Does cisco router's SIP trunk support more than one channels ( simultineous calls) or not?
2) If it doesnot support , how can I add second register and what is needed to use it for several calls at a time?
Solved! Go to Solution.
10-27-2013 03:09 PM
yes it support
confirm that you have the max accept command
voice service voip
sip
subscription maximum accept 100
subscription maximum originate 100
registrar server expires max 600 min 60
Haitham
10-27-2013 02:57 PM
Support for Multiple Registrars on SIP Trunks on a Cisco Unified Border Element, on Cisco IOS SIP TDM Gateways, and on Cisco Unified Communications Manager Expres:
http://www.cisco.com/en/US/docs/ios/voice/cube/configuration/guide/vb_9655.html
The Support for Multiple Registrars on SIP trunks feature has the following restrictions:
•Old and new forms of the registrar command are mutually exclusive: the registrar can be configured in either primary/secondary mode or multiple registrar mode—not both.
•Dynamic Host Configuration Protocol (DHCP) support is not available with multiple registrars (available for primary/secondary mode only).
•Only one authentication configuration per username can be configured at any one time.
•A maximum of six registrars can be configured at any given time.
•A maximum of 12 different realms can be configured for each endpoint.
•You cannot restrict the registration of specific endpoints with specific registrars—once a new registrar is configured, all endpoints will begin registering to the new registrar.
•You cannot remove multiple configurations of credentials simultaneously—only one credential can be removed at a time.
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
11-04-2016 02:38 PM
I have this same problem, how could you solve configure the two authentications?
10-27-2013 03:09 PM
yes it support
voice service voip
sip
Haitham
10-28-2013 05:44 AM
10-28-2013 06:42 AM
thank you very much, that worked for me, now I can made and accept more than one concurent calls on one registrer.
Just for information I still cannot use multiple registers, under sip-ua configuration mode I have 2 credentials with different usernames, 2 register-s with the same IP address, but cannot add second authentication parameteres with second username, so both credentials are using the same authentication username and password and hence I only have 1 registration, second is forbidden, I called my TSP and they say that two registration packets are comming , but with the same username and password, actually wich is configured under " authentication" parameter in "sip-ua" , so this is the output :
9954932203300 -1 25 yes
9954932203301 -1 25 no
as you can see first user is registered - 9954932203300, but the second - 9954932203301 is not, because the second is also using first's username and password, but the proxy is waiting for another.
10-28-2013 07:06 AM
Hi Dimitri,
Glad it worked for you
For multiple user authentication. There was a lot of issue with Cisco for this untill I hitnk 15.0
and you are 15.2
Confirm you can call in but can't call out
Also try these example of Cisco
The following example shows how to configure credentials for endpoints on a Cisco IOS SIP TDM gateway, Cisco Unified CME, or Cisco UBE to register with multiple registrars ("Example1.com" and "Example2.com") on a SIP trunk simultaneously:
Router> enable
Router# configure terminal
Router(config)# sip-ua
Router(config-sip-ua)# credentials number 1111 username MyUsername password MyPassword realm Realm.example1.com
Router(config-sip-ua)# credentials number 1111 username MyUsername2 password MyOtherPassword realm AnotherRealm.example1.com
Router(config-sip-ua)# credentials number 2222 username TheirUsername password TheirPassword realm Realm.example1.com
Router(config-sip-ua)# credentials number 2222 username TheirUsername2 password TheirOtherPassword realm AnotherRealm.example1.com
Router(config-sip-ua)# registrar 1 dns:example1.com expires 180
Router(config-sip-ua)# registrar 2 dns:example2.com expires 360
Haitham
Plz rate helpful posts
10-30-2013 05:32 AM
Hi hythamhadad
thank you for your response.
sip-ua
no remote-party-id
max-forwards 15
host-registrar
as you can see from this output I've configured 2 different credentials and 2 registrars without a problem, but
this parameter can be only 1 at a time and it is used for authentication with sip proxy, when I try to add second "authentication username .... " command it changes first one so no chance to have two different usernames, hence you I can only register with one registrar, because for the second one the same username is used and it is incorrect. This is the main issue. I hope that I explained correctly , if not please le me know
02-26-2018 12:04 AM
could you tell me, please, did you manage to handle this task ?
02-26-2018 12:19 AM
02-26-2018 12:23 AM - edited 02-26-2018 12:24 AM
This is CUBE. I have to register several accounts with one provider. Accounts have the same realm.
I have configured credentials and it seams that they are registered now, but it is only one authentication parameter available under sip-ua section
(the latest one re-writes others previously configured), so I doubt it will work properly.
02-26-2018 01:21 AM
02-26-2018 01:40 AM - edited 02-26-2018 01:46 AM
This is still not clear for me:
It is a part of the existing configuration.
sip-ua
credentials username USERNAME1 password PASSWORD1 realm asterisk
authentication username USERNAME1 password PASSWORD1
I am adding the second account:
ISR4321V(config)#sip-ua
ISR4321V(config-sip-ua)#credentials username USERNAME2 password PASSWORD2 realm asterisk1
(even with the different realm)
ISR4321V(config-sip-ua)#authentication username USERNAME2 password PASSWORD2
Updating username/password for realm
After that UPDATING only one authentication is left under sip-ua section in spite of it was configured for the other username. The first one is re-written.
02-26-2018 08:00 AM
02-26-2018 09:12 PM
