How to Configure SIP
roopesh.n
HI All,
We are planing impliment SIP in our organisation for making  Long distence calls .with present Setup we are using H.323 and PRI for making Calls. We need H323 and SIP at same time.
Please find the Our Network Diagram and Router Configuration.
Note: Our CCM Has no conectivity to internet.
Router Configutation:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2012.06.30 16:38:51 =~=~=~=~=~=~=~=~=~=~=~=
sh run
Building configuration...
Current configuration : 8338 bytes
version 12.4
service timestamps debug datetime
service timestamps log datetime
service password-encryption
hostname oh-rt2
boot-start-marker
boot system flash c3745-advipservicesk9-mz.123-26.bin
boot-end-marker
logging buffered 4096 notifications
enable secret 5 $1$AgBh$dCd1NSglSXBbZXmjcdO/I.
no aaa new-model
clock timezone IST 5 30
no network-clock-participate slot 2
no network-clock-participate slot 4
voice-card 2
dspfarm
dsp services dspfarm
voice-card 4
dspfarm
ip cef
ip domain name vmoksha.com
isdn switch-type primary-4ess
voice hunt user-busy
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
h323
sip
  bind control source-interface FastEthernet0/1
  bind media source-interface FastEthernet0/1
  transport switch udp tcp
  call service stop forced
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice class h323 1
h225 timeout tcp establish 3
fax interface-type fax-mail
controller E1 2/0
framing NO-CRC4
clock source internal
pri-group timeslots 1-24
description for BSnl
controller E1 4/0
framing NO-CRC4
pri-group timeslots 1-31
description For Outgoing
controller E1 4/1
framing NO-CRC4
pri-group timeslots 1-31 service mgcp
description For Incoming BSNL
ip tcp synwait-time 13
interface Multilink1
bandwidth 256
ip address 172.16.16.45 255.255.255.252
ip tcp header-compression iphc-format
ppp multilink
ppp multilink group 1
ip rtp header-compression iphc-format
interface FastEthernet0/0
ip address 10.10.14.5 255.255.255.0
ip broadcast-address 10.10.14.255
ip accounting output-packets
ip nbar protocol-discovery
ip route-cache flow
no ip mroute-cache
duplex auto
speed auto
h323-gateway voip bind srcaddr 10.10.14.5
interface Serial0/0
description Circuit #1 initiating in India via Bharti
bandwidth 128
no ip address
encapsulation ppp
no ip route-cache cef
no ip route-cache
no ip mroute-cache
clock rate 2000000
ppp multilink
ip address 10.10.3.10 255.255.255.0
duplex auto
speed auto
no cdp enable
interface Serial0/1
description Circuit #2 initiating in India via BSNL
bandwidth 128
no ip address
no ip route-cache
no ip mroute-cache
clock rate 2000000
interface Serial0/2
description initiating in India via TATA
bandwidth 128
no ip address
encapsulation ppp
clock rate 2000000
ppp multilink
interface Serial0/3
no ip address
shutdown
clock rate 2000000
no cdp enable
interface Serial2/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
no cdp enable
interface Serial4/0:15
no ip address
encapsulation hdlc
no cdp enable
interface Serial4/1:15
no ip address
encapsulation hdlc
isdn bind-l3 ccm-manager
no cdp enable
ip forward-protocol nd
ip route 10.10.0.0 255.255.0.0 10.10.14.1
ip route 172.18.252.0 255.255.255.192 10.10.14.1
ip route 192.168.2.0 255.255.255.0 10.10.3.111
ip route 203.92.42.2 255.255.255.255 10.10.3.1 permanent
ip http server
logging trap errors
access-list 1 permit 10.10.3.18 log
access-list 1 deny   any
access-list 2 permit 10.10.3.18 log
access-list 2 deny   any
dialer-list 1 protocol ip permit
snmp-server community public RO 1
snmp-server community private RW 2
snmp-server location OH/BLR/IN/vMoksha
snmp-server contact ravinder@vmoksha.com
snmp-server enable traps tty
control-plane
voice-port 1/0/0
voice-port 1/0/1
voice-port 1/1/0
cptone IN
timeouts interdigit 3
connection plar 500
voice-port 1/1/1
cptone IN
connection plar 500
voice-port 2/0:15
connection plar 500
voice-port 3/0/0
cptone IN
connection plar 810
voice-port 3/0/1
cptone IN
connection plar 500
voice-port 3/1/0
cptone IN
connection plar 500
voice-port 3/1/1
cptone IN
connection plar 500
voice-port 4/0:15
connection plar 500
voice-port 4/1:15
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.10.14.11
ccm-manager config
mgcp
mgcp call-agent 10.10.14.11 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp profile default
sccp local FastEthernet0/0
sccp
sccp ccm 10.10.14.11 priority 1
dspfarm rtp timeout 60
dial-peer cor custom
dial-peer voice 3 pots
service mgcpapp
direct-inward-dial
dial-peer voice 4 pots
service mgcpapp
dial-peer voice 5 pots
service mgcpapp
dial-peer voice 3000 voip
destination-pattern 3...
session target ipv4:160.100.160.151
dial-peer voice 9999 voip
destination-pattern 9T
dial-peer voice 6 pots
service mgcpapp
dial-peer voice 14 pots
destination-pattern 0T
progress_ind setup enable 3
progress_ind progress enable 8
progress_ind connect enable 8
direct-inward-dial
port 4/0:15
dial-peer voice 101 voip
destination-pattern 7..
session target ipv4:10.10.14.11
dtmf-relay h245-alphanumeric
codec g711ulaw
ip qos dscp cs5 media
no vad
dial-peer voice 102 voip
destination-pattern 8..
codec g711ulaw
no vad
dial-peer voice 103 voip
destination-pattern 9..
codec g711ulaw
no vad
dial-peer voice 104 voip
codec g711ulaw
no vad
dial-peer voice 105 voip
destination-pattern 6..
codec g711ulaw
no vad
dial-peer voice 106 voip
destination-pattern 5..
voice-class codec 1
voice-class h323 1
incoming called-number .
no vad
dial-peer voice 30 pots
preference 2
destination-pattern *5T
dial-peer voice 77 pots
preference 2
destination-pattern *7T
dial-peer voice 29 pots
preference 1
port 1/1/0
dial-peer voice 78 pots
preference 1
port 3/0/1
dial-peer voice 2 pots
incoming called-number 8025053.T
direct-inward-dial
dial-peer voice 1 pots
description **** For Income Dial Peer***
direct-inward-dial
port 4/0:15
dial-peer voice 11 pots
description **For income dial*****
direct-inward-dial
dial-peer voice 45 pots
preference 2
destination-pattern *8T
dial-peer voice 44 pots
preference 1
port 3/0/0
dial-peer voice 55 pots
preference 2
destination-pattern *4T
dial-peer voice 54 pots
preference 1
port 3/1/0
dial-peer voice 95 pots
preference 2
destination-pattern *6T
dial-peer voice 94 pots
preference 1
port 1/1/1
dial-peer voice 5555 voip
destination-pattern *9T
session protocol sipv2
session transport tcp
num-exp 8025053... ...
gateway
timer receive-rtp 1200
sip-ua
authentication username 123456 password 256487675C
registrar ipv4:10.10.14.11 expires 3600
sip-server ipv4:x.x.x.x
gatekeeper
shutdown
banner motd ^C
!!!AUTHORIZED ACCESS ONLY !!!
Hostname : OH-RTR2.
Contact  :IS Helpdesk
!!! AUTHORIZED ACCESS ONLY !!!
^C
line con 0
transport output all
line aux 0
transport preferred none
transport output none
line vty 0 5
password 7 1511021F0725
login
transport input all
ntp clock-period 17180604
ntp server 10.10.8.1
end
Roopesh
12 Replies 12
Chris Deren
Who is your SIP provider?
Config may vary based primarily on whether they need authentication or not.
Have you searched this forum for examples as similar question was posted many times before.
SIP and H323 can coexist on the same router but SIP requires CUBE licenses when integrating to SIP provider.
Chris
Hi chris,
Thanks for the Replay.
Our SIP provider is TATA Communications. They have Given the User ID and Password  also SIP Proxy address.
We need help in configuration whether we need to configure the authentication in our Getaway(Router) or in CCM.
Please suggest.
Roopesh
Authentication can only be done on CUBE as CUCM does not support authentication of SIP trunks (one of many benefits of having CUBE).  So, you configure SIP trunk between CUBE and CUCM that is not authenticated and CUBE and service provider that configures authentication, you can either define the credentials on dial-peers or under sip-ua.
HTH,
Chris
TATA provider normally accept this format:
sip-ua
credentials number XXXXXXX username XXXXXXX password XXXXXXXX realm X.X.X.X(proxy-server IP)
authentication username XXXXXXX password XXXXXXXX
registrar ipv4:X.X.X.X expires 3600
sip-server ipv4:X.X.X.X
I have similar setup, but i want to know wether logical partitioning is required for such scenario.
Below is my setup.
Do i need to Deploy Logical Partition on ISR 4321 (India) or CUCM which is located in INDIA.
I have a CUCM Cluster (Pub & Sub) , UCCX cluster (HA Mode) & 1 Voice gateways ISR 4321 (All at one location)
We have one PRI terminated, on a Voice Gateway (ISR 4321).
Configured SIP for PRI PSTN call routing between CUBE and CUCM.
IP Phones are for contact centre agents. (All users are using CIPC via VPN and located anywhere across the globe.)
We have one SIP Trunk from ITSP for ISD calling, which is terminated on the same ISR 4321 router.
So now my question is can we configure Logical Partitioning to avoid Toll Fraud between SIP Trunk and PRI.
Please note that SIP Trunk and PRI both are terminated on same route
You mentioned that the CC agents are located anywhere across the globe. Do they have a DID number to reach them or how the external users will be dialing into the Contact center ?
The agents are located I mean they are using CIPC over vpn from their laptop.
Means they can be in any part of the world.
Ok. Can the agents make outbound calls ? If they can, how is that call routed out ?
If you have Local Gateways in each country for routing outbound calls, then definitely you need to configure Logical partitioning. However if you only have Gateway in India and any outbound calls made by remote agents (logging in via VPN globally) are routed only via this gateway or agents wont make any external call, then there is no need for Logical partitioning config.
Rajan
Please rate all useful posts by clicking the star below and mark solutions as accepted wherever applicable
this setup has ITSP SIP trunks and E1 trunks.
Got it. As I mentioned where you have these. If you have these in India gateway and any external calls from any agents registering via VPN goes through this alone, then there is no need for logical partitioning config.
Rajan
please rate all useful posts by clicking the star below
Setup is in india itself.
