12-17-2010 05:31 AM - edited 03-16-2019 02:29 AM
i have UC520/540 with CME 7.1
i was just wondering, if it is possible to configure a sleep mode for a c7970 ?
maybe for an emergence phone constalation, where the display should not turn in sleep mode. i could not find an answer or option for this.
Solved! Go to Solution.
12-17-2010 05:42 AM
Hi Kenjie,
Here is the method to turn off the 7970 display for CME
The following example shows how to set the backlighting parameters so that there is no backlighting of the phone display for all Cisco Unified IP phones with backlight capabilities until there is user interaction with the phone. The backlightIdleTimeout parameter is configured so that the backlight will switch off again after 60 seconds of inactivity.
Router(config)# telephony-service
Router(config-telephony)# service phone daysBacklightNotActive 1,2,3,4,5,6,7
Router(config-telephony)# service phone backlightOnTime 07:30
Router(config-telephony)# service phone backlightOnDuration 10:00
Router(config-telephony)# service phone backlightIdleTimeout 00.01
Router(config-telephony)# create cnf-files
Router(config-telephony)# reset all
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_s1ht.html#wp1083963
Hope this helps!
Rob
12-17-2010 05:44 AM
Check:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_s1ht.html#wp1135324
Oh, Rob beats me to it +5 Rob!
12-17-2010 05:42 AM
Hi Kenjie,
Hope this helps!
Rob
01-18-2011 11:53 AM
I am using:
service phone displayIdleTimeout 00:01
service phone backlightIdleTimeout 00:01
I cannot get it to sleep.
Any thoughts?
12-17-2010 05:44 AM
Check:
12-17-2010 05:49 AM
Paolo,
That is the first time ever that my Baboon-like typing skills beat anyone +5
Happy Holidays!
Rob
12-17-2010 06:28 AM
Thanks to both of you for your advice and support.
That's what i searched, but not found..
