How to configure VoIP through firewall
max_gbp777
We have a VoIP solution that is currently directly connection from the ISP router into our network. I need guidance on how to configure VoIP to traverse a firewall.
We have a secure redundant solution for the data connection, but I have no idea when it comes to VoIP as to which ports and protocols to allow/ block with achieving optimum security.
  • This is a Hosted Voice Solution with Call Manager at the ISP.
  • There is a PA-2FE-TX card that provides the VoIP from the router.
  • The router provides DHCP for the Phones only.
  • There is an internal windows DHCP for the PCs.
  • Data and VoIP provided by same ISP.
Attached are diagrams of a) current set-up and b) what I’m aiming for.
Any help is appreciated. Thank you.
Your phones use SCCP or SIP protocol to communicate with CM + TFTP for config and firmware, you need to open RTP stream to phones - not sure where is your voice GW. Probably you will need HTTP/HTTPS or someting more like LDAP or Cisco Directory.
More less that's all but best option is to check with ISP what need to be open exactly.
rate if this help
Adam Thompson
Level 4
Level 4
Take a look at this: http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/prod_maintenance_guides_list.html
There is a TCP and UDP port usage document under each version of Call Manager. They are a pretty good guide as to what you may need to open in your firewall.
Adam
Please rate if helpful
