How to correlate between CDR and TCD for who disconnected the call
RAVIKUMAR J K
Hi Everybody,
We have ucce 8.0 with cucm 8.0.3, Is there any way we can find out for a perticular Agent who disconnected the call ?(Customer or Agent) for a month from CDR and TCD?
I heard this can be done using Peripheral key of TCD and CallMgrID and GlobalCallMgrID_CallId of CDR, we have tried it but it will work for some of the calls and for some calls it will not work.
I appreciate your precious help on this.
will.alvord
Level 5
Level 5
I haven't worked with UCCE much and there are certainly several topology choices, but as long as CUCM is aware of the call and you have enabled CMR collection (CallManager service parameter -> Call Diagnostics Enabled)...
I do recall that the call flow is pretty all over the place so there are other considerations such as when the call is split, transfers, etc which this document speaks to:
Understanding Cisco Call Detail Records - http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/6_0_1/car/carcdrdef.html
However, for normal calls this is valid...
In particular, the fields you are after are:
* origCause_value (http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/6_0_1/car/carcdrdef.html#wpmkr1081211)
* destCause_value fields (http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/6_0_1/car/carcdrdef.html#wpmkr1081234)
So you also have to know the direction of the call in addition to generally understanding your topology and call flow.
Hope that helps,
will
Hi Well,
Thank you very much for your assistance.From CDR using above mentioned values we can find out who disconnected call.
But if I want for a perticular agent to find out who disconnected the call for a month,
1. From CUCM CDR, it is like i need to take each and every ANI landed to this Agent and Manually do it.
2. But suppose AGENT has recieved around 900 calls in a month then it is very difficult to find out from CDR for every call.
I am asking is there any way we can correlate ICM Termination_Call_Detail of a call with CDR data and find out who disconnected the call?
so that i can pull out required info for a perticular Agent in a less cumbersome way.
There isn't a canned way to do that.  I'm not saying that it's not possible, just saying that there will be more  involved than just clicking a button.  Sorry I couldn't be more help.
