Hi All,
I am not sure is it possible to write a command list that works every Sunday to reset any ISDN PRI interface?
İf it is possible please share with me. Thanks.
Mehmet,
You can create an EEM script and put the commands needed to reset your PRI interfaces. Below is a link on how to setup an EEM script.
http://www.cisco.com/c/en/us/support/docs/ios-nx-os-software/ios-embedded-event-manager-eem/116176-technote-eemscripts-00.html
Yosh
I suggest to use a tool which can assist to do this and maintain logs of the activity, etc. Something like solarwinds NCM
Hi Mohammed,
I think there is misunderstanding.
I am not talking about any tool. I just want to create a scheduled command on Cisco router and that command should reset PRI on router. I don't want to reset PRI interfaces manuelly on router every Sunday. I want to create scheduled command that do this automatically.
Then use EEM script in the router as suggested below by Yahsiel.
