Beginner
How to customized GUI of Unity Connection CiscoPCA or CUCM ccmuser?
Has anyone customized GUI portal of Unity Connection Cisco PCA or CUCM ccmuser GUI ?
We have certain requirement where we want to disable specific functions for end users.
Thanks..
2 REPLIES 2
Highlighted
Hall of Fame Cisco Employee
CCMuser you can configure what is available under enteprise parameters.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Highlighted
Beginner
Thanks Jamie!
Actually I am keen to  see customization on Unity Connections web inbox. Looks like it is as standards as we see.
I thought somewhere should be an option, like we customize phone menu's.
Cheers,
