02-23-2015 10:06 AM - edited 03-17-2019 02:05 AM
Hi all,
How do I trace a Single Number Reach call in my voice gateways? I've tried all the debug commands and cannot see the calls. I know the calls are going out becuase I'm receiving them on my mobile but, I need to see what is being sent.
Running:
CUCM v. 9.12.
Cisco 3925 Voice Gateways w/ Version 15.2(2)T3
Chris
02-23-2015 01:03 PM
Hi Chris.
How is your VG connected to the PSTN (SIP-E1/T1-Analogue)?
The starting point could be debug voip ccapi inout
Please let me know
Carlo
02-23-2015 01:28 PM
Carlo,
Thanks for the reply. VG is connected to the PSTN via T1-PRI. I ran the following debugs:
debug isdn q931
debug isdn q921
debug ccsip messages
Chris
02-23-2015 01:41 PM
Chris,
Apologize about not reading the complete post!
(debug isdn q931) should show you what is being sent over to PSTN. no output when issue the above debugs? if so, please try the following commands:
conf t
logginng on
logging mon 7
exit
term mon
Then make a test call.
Thank you,
Shadi
02-23-2015 09:34 PM
Hi Chris.
Debugging isdn q931, are you able to see other calls log?
on vg do what follows
conf t
logging buffered 4096
logging monitor debug
logging enable
try to activate debug isdn q931 again
Carlo
02-24-2015 06:38 AM
Carlo,
Thanks again for the help. I must not have had the logging enabled fully, I see the calls now. We are having issues with calls showing up as Unavailable instead of displaying the phone number. It's just started the last month and there have been no changes. Some people have the problem all the time and some people have the problem with random calls. Other than our voice carrier the users have nothing in common. Different mobile phones & different carriers. There have been reports of users calling customers and are all of a sudden coming up as Unavailable. ?????
Chris
02-24-2015 07:54 AM
Hi Chris.
With "Unavailable" do you mean Unknown?
If it appears randomly you can activate a permanent debug isdn q931 and send the log to a syslog server in order to verify if there is a similar event, such as same B channel selected, that happens when remote user doesn't display correct Calling number.
I would also check with my Provider which could be the cause :)
Carlo
02-24-2015 08:00 AM
Hi Carlo,
When the call comes in to the mobile it shows as Unavailable but, the call log on the phone shows Unknown. So, I guess in this case the words are inter-changeable. I know the numbers are leaving the GW's becuase I see them and this just started happening but, to random people.
Best,
Chris
02-23-2015 01:27 PM
Hello Chris,
In addition to (debug voicp ccapi inout), I recommend collecting CallManager logs to confirm whether the call leaving CUCM into te VG or not.
Thank you,
Shadi
02-23-2015 01:32 PM
Hi Shadi,
I know the calls are going out my VG's because the mobile phone rings and I can answer the call. I cannot see the call info in the VG when it goes out or when the call is active.
Chris
