how to disable CDR for one extension number
wildflower1977
My client has a few extensions configured with an 'access door' feature so when the number is dialled a remote doorlock is unlocked.  One of the doors does not close properly and each time it 'bounces' on the latch a CDR is being generated.  As some of the doors are very busy the CDR logs are getting clogged up with these doors in contant use.  I have read though some CDR configuration notes and have found some sections on disabling CDR (entirely) or using the RTMT to clear the CDR/CMR buffers, but nothing that can be configured on a specific extension.
The current version of CUCM is 4.1 but the site is being migrated to CUCM8.5 at present.
If anyone has any pointers or needs further information please ask!
paolo bevilacqua
Wrong forum, try "IP Telephony". You can move your post using the control panel on the right.
wildflower1977
so, does anyone have any suggestions to try no its in the right forum?
That's not possible, CDR is either ON or OFF for the whole server in which the parameter is configured.
Any DN which is registered on a server where CDR is ON will generate CDR data.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Rob Huffman
Hi there,
It's possible that disabling this parameter "CDR Log Call with Zero Duration Flag" might get rid of these
records as they may be 0 seconds in length
Cheers!
Rob
"Everything is broken" - Bob Dylan
