How to disable fixed Hold-Transfer-Conference Key on 78XX
Malte_P_Scheuss
for a special department i'd like to disable those 3 fixed button on several 7841 phone:
I already deleted them on the softkey template.
Usecase:
The user should not use the features on the phone, nothing else.
Wish:
like the phone button & sofkey templates, i am looking for am option to disable those 3 buttos on a device profile, not on the phone, but thats a wish.
Jaime Valencia
That's not possible, they cannot be disabled.
You can only disable their ability to use conference by not providing them with a MRGL with a CFB, but not the other two.
java
if this helps, please rate
