How to disable the Summer Time in CUCM11.0
iantra123
Level 3
Level 3
I have a CMBE6K-S preconfigured.
The problem is that the CUCM was configured with a timezone with Summer Time (Dst) enabled.
I want to remove the DST, so my timezone will be OK. I've already changed the NTP reference, or the Date/Time Group but no success.
When I check on the CLI I still see the dst and the original timezone where Cisco has preconfigured the CUCM.
We are in a region (emea) that not need the DST. (GMT+3 Nairobi).
how to do it?
Antra
Mohammed Khan
Refer below link to update/change DST
https://supportforums.cisco.com/discussion/11286791/cucm-timezone
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/118744-technote-cucm-00.html
You can view the list of available time zones with this command:
admin:show timezone list
   0 - Africa/Abidjan
   1 - Africa/Accra
   2 - Africa/Addis_Ababa
   3 - Africa/Algiers
   4 - Africa/Asmara
   5 - Africa/Bamako[...]
405 - Europe/Warsaw
And time zones on CUCM can be set with this command:
admin:set timezone 405
Using timezone: Europe/Warsaw
A system restart is required
In this command, 405 is the mapping of the 405 to the Europe/Warsaw time zone.
Luis Subdias
