Highlighted
Beginner
How to E1 Trunk between cisco 2851 and cisco 2811
Hi everybody.. I newby in cisco VOIP world.
I would appreciate if someone could help me with the configuration of a cisco router trunk e1 between 2851 and cisco router 2911.
Cisco 2911 has VWIC2-MFT-G703 card and Cisco 2851 has VWIC2-2MFT-T1E1.
Regards & Thanks in advance.
Everyone's tags (5)
1 ACCEPTED SOLUTION
Highlighted
VIP Mentor
Two things:
1. A lot of the configuration has already been provided above.
2. If you search on this forum on online using google you will see how to configure E1 interfaces..
E1 G703 is not a protocol, its an E1 interface type and this is not configurable. Its a hardware specification
Euro ISDN ETSI is not a valid swicth type for ISDN PRI, the closes where euro ISDN is used is in BRI interfaces
NO CRC is configured under the E1 controller..Please look online and see how to configure this...it is a simple command.
Eg controller e1 0/0/0
framing no crc4
B channels are configured using pri-group time slots command, which again is in the config above.
Configuring the router as the network side is also in the config above..
Links on how to configure E1
http://www.icciev.com/1/post/2011/7/configure-cisco-2821-router-as-an-e1-trunk-gateway.html
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_tech_note09186a00800f99bb.shtml
http://www.cisco.com/en/US/products/hw/routers/ps274/products_configuration_example09186a0080094691.shtml
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
6 REPLIES 6
Highlighted
Hall of Fame Master
This has been asked few times here before. High level steps:
1. configure network-clock-participate and include these cards on both sides
2. Define card type as E1
3. configure default isdn switch type
4. configure controller for PRI
5. configure one side as network side
6. connect cards with cross over E1 cable
7. configure dial peers pointing to each other
HTH,
Chris
Highlighted
Beginner
Thanks  a lot  for the guide.. Could you send me a configuration example of all these steps ... ?.
I would appreciate a lot..
Many Thanks..
Highlighted
Hall of Fame Master
Here you go:
Steps 1 - 4  from config t:
network-clock-participate wic 0
network-clock-select 1 T1 0/0/0
card type t1 0 0
isdn switch-type primary-ni
controller T1 0/0/0
clock source internal
pri-group timeslots 1-24
description QSIG PRI
step 5
interface Serial0/0/0:23
no ip address
no ip redirects
encapsulation hdlc
isdn switch-type primary-qsig
isdn timer T310 120000
isdn protocol-emulate network
isdn incoming-voice voice
isdn supp-service name calling profile Network-Extension operation-value-tag local
no isdn outgoing display-ie
no cdp enable
step 7
dial-peer voice 1001 pots
port 0/0/0:23
destination-pattern 4... (assuming 4000 - 4999 point to other side)
progress_ind setup enable 3
progress_ind progress enable 8
forward-digits 4
Chris
Highlighted
VIP Mentor
In addition to chris excellent guide (+5 chris) Dont forget to configure your clock source appriopriately. Configure your routers such that your clocking is derived from the network side.
Beginner
Hi Guys.
Thanks a lot for responses
They were of big help for me..
I will start a Cisco voice course on October, but before at work are asking to me , to do many things of Cisco IP Telephony.
This time, are asking to configure another voice trunk E1 with config below:
There are the same router with following hardare:
2911 VWIC2-MFT-G703 card and Cisco 2851 has VWIC2-2MFT-T1E1.
"E1 G 703 protocol: select Euro ISDN ETSI, NO CRC, B channels from 1 to  31;  network side at the end router where CCUM Express will be running".
I would appreciate if someone could help me with the configuration & some example.
Thanks a lot.
Highlighted
VIP Mentor
Two things:
framing no crc4
