How to enable audio on DX80
Hi ,
Please help me to enable video calling on Cisco DX 80 .
I have setup the devices and its registered with Call manager .
It is on SIP .
5 Replies 5
M02@rt37
Hi shantanu.adhya@tcs.com
Do you configure on CUCM the System/Region setting for maximum session bandwidth bitrate for video calls?
If yes which is the Bw bitrate?
Try 384K.
Best regards
The bitrate for video is set to 384 Kbps .However that didn't work.
Any license issues ?
Hope this helps!
Cheers
Rath!
***Please rate helpful posts***
Nope
Ratheesh Kumar
Hi there
In CUCM try changing the System/Region to 384K and see that helps.
Hope this helps!
Cheers
Rath!
