06-19-2018 10:12 AM - edited 03-17-2019 01:02 PM
Hi ,
Please help me to enable video calling on Cisco DX 80 .
I have setup the devices and its registered with Call manager .
It is on SIP .
06-19-2018 10:39 AM - edited 06-19-2018 11:47 AM
Do you configure on CUCM the System/Region setting for maximum session bandwidth bitrate for video calls?
If yes which is the Bw bitrate?
Try 384K.
06-20-2018 01:56 AM
The bitrate for video is set to 384 Kbps .However that didn't work.
06-20-2018 07:22 AM
Any license issues ?
Hope this helps!
Cheers
Rath!
***Please rate helpful posts***
06-22-2018 07:38 AM
Nope
06-19-2018 11:19 AM
Hi there
In CUCM try changing the System/Region to 384K and see that helps.
Hope this helps!
Cheers
Rath!
