07-02-2011 12:02 AM - edited 03-16-2019 05:44 AM
I have following commands on my h323 gateway. On CUCM, SRST is enabled and i have given my h323 gateway and SIP port is 5060.
call fallback active
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 10.1.209.1 port 2000
max-ephones 250
max-dn 500
dialplan-pattern 1 905 extension-length 11
cor incoming user1 default
I have following question, will this work for Cisco phones having SCCP protocol?
My sip phones are registered with follwoing commands
voice register global
mode cme
source-address 10.1.209.1 port 5060
max-dn 300
max-pool 165
authenticate register
Solved! Go to Solution.
07-02-2011 12:51 AM
Yes i know , you can use the telephony service as a new function called CME over SRST , it gives you CME functionality over the SRST config , you can try it , it will work normally.
Amer
07-02-2011 12:29 AM
Why don't you use telephony service instaed of call-manager-fallback , it is better in your case.
Amer
07-02-2011 12:46 AM
I am not using CUCME as i told i am using CUCM 7.1 and H323 Gateway
07-02-2011 12:51 AM
Amer
07-02-2011 01:10 AM
So, i can put all the config under call-manager-fallback under telephony-service? If so, what will be difference? Is there any standard configuration for Cisco IP phones (SCCP) to work under link failure?
Telephony service is not accepting the below command.
07-02-2011 01:32 AM
It's a corlist , not cor and it is on the dn template, here is a template we use evertime we configure a CME-SRST
telephony-service
srst mode auto-provision all
srst ephone template 1
srst dn template 1
srst dn line-mode octo
max-ephones XX
max-dn XX
ip source-address XX.XX.XX.XX port 2000
time-zone 31
date-format dd-mm-yy
call-forward pattern .T
moh music-on-hold.au
multicast moh 239.1.1.1 port 16384 route XX.XX.XX.XX
transfer-pattern .T
secondary-dialtone 9
ephone-dn-template 1
corlist incoming CSS-Mobile
07-02-2011 01:37 AM
Also you need to conisder some SIP related config
For SIP SRST mode you need to
Srst example for SIP
Voice service voip
Allow-connection Sip to SIP
Allow-connectionSIP to H323
SIP
Bind control source-interface [ ur lan interface ]
Bind media source-interface [ur lan interface
Registrar server
Voice registrar global
Max-dn [number]
Max-pool [number]
Voice register pool 1
Ip network x.x.x mask y.yy,y
Application sip.app
Dtmf-relay rtp-nte
Codec g711ul
Cor incoming [ ur cor here for SIP ]
Good luck
If helpful Rate
07-02-2011 04:15 AM
So, now i can conclude following
For SCCP SRST ( In other words, Cisco Phones)
We use Call-manager-fallback or Telephony-Service ( which is also CME-SRST) command
For SIP SRST (Port 5060)
We use Voice registrar global command
07-02-2011 04:20 AM
what does this command do " srst mode auto-provision all "
what does this command do " srst ephone template 1 " and we didnt create any template ?
what does this command do " srst dn line-mode octo "
what does this command do " secondary-dialtone 9 "
Thanks for your support.
07-02-2011 05:18 AM
Means when phone go to srst put all config in show run (no need to do it manually , when you go to srst , do a sh run and you will find all the config (ephone , ephone dn , etc..) in the show run.
Means when phones go to srst use template 1 for all learned phones , at the nd my post there is a template.
Means single line has 8 channel, when the phones go to SRST , it will save the config for each dn as octo-line (Busy trigger 8)
When user press 9 They here secondary dialtone it's not necessary but sometimes the cutsomers asked for .
Amer
07-02-2011 06:32 AM
For incoming calls / outgoing calls during SRST mode,
what will be the dial peers??. Is there any standard and template to make it work. Thanks for consistent help.
07-02-2011 06:37 AM
No , as i am sure you know , everyDN in the SRST is a dial-peer , so when the call come in and the extension is available , it will be forwarded direclty .
In case of outgoing , as i saw in your post this is a H.323 gateway , so the phones will use the same dial-peers that are already configured on the gateway .
Amer
07-02-2011 08:34 AM
SO YOU MEAN TO SAY, DO I NEED TO CREATE EVERY DN AND EPHONE ON GATEWAY IN ORDER TO WORK IN SRST MODE ??? lIKEWISE I REGISTERED SIP BY PUTTING FOLLOWING COMMANDS
voice register dn 1
number 1234
name ABCD
voice register pool 1
id mac 0004.F221.XXXX
number 1 dn 1
cor incoming user2 default
username ANYUSER password 123456
codec g711ulaw
FOR SCCP PHONES ( WHO ARE USING TELEPHONY-SERVICE ) COMMAND TO WORK UNDER SRST CONDITION, I NEED TO CREATE THOSE EXTENSION ON GATEWAY TOO. LETS SAY IF I PUT COMMAND
srst mode auto-provision all, IT CAN DOWNLOAD THE PHONE INFO FROM MY CUCM.
FOLLLOWING IS THE TELEPHONY-SERVICE CONFIG
telephony-service
max-ephones 165
max-dn 500
ip source-address 10.1.211.1 port 2000
time-zone 21
time-format 24
dialplan-pattern 1 90[234567]....... extension-length 10
dialplan-pattern 2 905........ extension-length 11
moh music-on-hold
transfer-pattern .T
07-02-2011 12:54 PM
Listen , i am not really sure about SCCP and SIP at the same time as SRST , i think i read it somewhere that in case of SRST it is either SCCP or SIP but i am not sure , i am may be mistaken .
about the sccp:
You need to create the dn and ephone manually only on case you are using telephony service , not call manager fallback , so that you can configure more feature on the SRST , even you can configure extnesion mobility, so that's why procision all is better to be used.
About loading , every ip phone has a device pool , in this device pool there is a srst reference , so that the phone at the registeriation from the CCM , it will download this info into the ip phone , when the call manager become unavailable , the phone will try to register with the SRST gateway , at that time , the gateway will check if this ephone is already configured , if it is it will give the ip phone the config related to , otherwise if the auto prevision is on , the gateway will write the config into the gateway so it can be used .
Hope this is clear.
Amer
07-02-2011 09:51 PM
thanks alot for detailed info.
I have implemented SRST for SIP phones and following is the config
voice register dn 1
number 2598
name test
id mac 0004.F224.xxxx
number 1 dn 1
username test password 123
codec g711ulaw
Everything is fine as i can dial outside from that extension. But when i dial inside, after message from ivr, then it seems it couldnt find the extension created on the router. I can see the virtual dial-peer created by gateway.
Any clue???
