It depends on the way telco configured your analog ports and the hunting mechnism used. Some telcos uses one to one mapping by mapping DID to ports upon your request. While others won't do this and will give a pilot range used by all ports.
There is no show command to verify this. But you can make test calls to outside and verify the caller id.
