01-27-2016 12:53 PM - edited 03-17-2019 05:38 AM
As titled.
Is there a way by using show and debug commands to figure out what are the PSTN assigned numbers to FXO ports?
Thanks in advance.
01-27-2016 08:07 PM
I don't think it is possible. Analog circuit (Telco) doesn't provide own number during call setup in any way.
- Vivek
01-27-2016 08:13 PM
It depends on the way telco configured your analog ports and the hunting mechnism used. Some telcos uses one to one mapping by mapping DID to ports upon your request. While others won't do this and will give a pilot range used by all ports.
There is no show command to verify this. But you can make test calls to outside and verify the caller id.
