How to figured out the PSTN assigned numbers on FXO ports?
As titled.
Is there a way by using show and debug commands to figure out what are the PSTN assigned numbers to FXO ports?
Thanks in advance.
Vivek Batra
Engager
Engager
I don't think it is possible. Analog circuit (Telco) doesn't provide own number during call setup in any way.
- Vivek
Mohammed al Baqari
VIP Advisor VIP Advisor
VIP Advisor
It depends on the way telco configured your analog ports and the hunting mechnism used. Some telcos uses one to one mapping by mapping DID to ports upon your request. While others won't do this and will give a pilot range used by all ports.
There is no show command to verify this. But you can make test calls to outside and verify the caller id.
Recognize Your Peers
