Beginner
How to forward inbound calls based on caller ID?
Can anyone tell me or share a document that explains how to forward a inbound call based on the caller ID that is coming across. Basically just looking for a way to say if XXX-XXX-XXXX is calling in, then forward all the calls to extension XXXX.
Jason
5 REPLIES 5
Rising star
Re: How to forward inbound calls based on caller ID?
Look at this document, https://supportforums.cisco.com/docs/DOC-18367
Please remember to rate all useful posts.
Please remember to rate helpful responses and identify helpful or correct answers.
Highlighted
Beginner
Can this be done on the router? Rather than in CM?
Rising star
You could use a combination of a caller id specific incoming dial peer and a voice translation rule to achieve that on the VGW. On the dial peer use answer address as the match to intercept the calling number and tie a incoming translation rule that transforms the called number to the destination of your choice.
Beginner
Would you happen to have a example config for this setup on the router?
Rising star
This is from memory, so there might be one or two typos. :) If needed I can give you a more exact answer tomorrow when I'm at work and have access to a bunch of configuration examples, but I think you should manage to figure it out with this.
Incoming dial peer
dial-peer voice 1 pots
answer-address 555123456789 <- caller id you'd like to match calls from.
direct-in dial
translation-profile incoming IN-ANI-REDIRECT
Translation rule
voice translation-rule 1
rule 1 /.*/ /1000/ <- match anything and translate to 1000. Use whatever DN on the replace part to suite your needs.
voice translation-profile IN-ANI-REDIRECT
translate called 1
Content for Community-Ad
August's Community Spotlight Awards
