configure & troubleshoot anyconnect
159
Highlighted
Beginner
How to generate user logged in reports on Jabber?
How to generate user logged in reports on Cisco Jabber?
Ex: Cisco Jabber connected users today.
Everyone's tags (1)
5 REPLIES 5
Hall of Fame Cisco Employee
Re: How to generate user logged in reports on Jabber?
Unfortunately there is no such report, you can get some real time information via CLI on who is connected, but not a report over a certain period of time.
java
if this helps, please rate
Beginner
I understand, which command should I use?
run pe sql ttlogin select * from clientsessions
Depending on your IM&P, you might have a presence usage report under IM&P reporting which would also provide real time info
java
Beginner
For my own education as well.  I would usually look at XMPP connections using RTMT to see how many jabber clients were connected.  Is that not a valid method?  Have I been doing it wrong this whole time? lol
There are a few ways, mostly depends on what you're looking for, or if you have access to RTMT or not.
java
Content for Community-Ad
June's Community Spotlight Awards
