11-01-2012 11:19 AM - edited 03-16-2019 01:58 PM
Can someone tell me te command to use to get the List.xml from from my CUCM 8.6.2 server? It is located in the Desktops/640x480x24 folder. Do I need to TFTP client on my desktop to do this?
Thank you
Solved! Go to Solution.
11-01-2012 11:39 AM
Assuming you do not have a NACL, FW, etc. blocking access, you can certainly use a TFTP client from your desktop to retrieve the files. You can also web to the TFTP service (http://
Multiple ways to get at the content.
HTH.
-Bill (http://ucguerrilla.com)
11-01-2012 11:39 AM
HTH.
11-01-2012 12:23 PM
Thank you William. I was able to use the URL method.
11-09-2012 10:09 AM
I was using the CLI method, but was getting a invalid directory error. The URL method was a success. Neat-O!
