How to get unity connection the pre recorded system greeting?
MehmetKaya
     I want to collect the pre re recorded system greeting.  Is there any way to get the pre recorded system greetings. I will collect and edit that wav.
2 Accepted Solutions
You cannot get or change the built-in greetings, you would need to record and upload such greeting under the std greeting for your users/call handlers.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
it's possible to obtain wav files (greetings + voice messages), BUT you need to have a root account
Greetings wav files are located here
/var/opt/cisco/connection/lib/streams
Voice messages wav files are stored here:
/var/opt/cisco/connection/mail/unitymbxdb1
Vadym
8 Replies 8
MehmetKaya
I need the standart greeding promt( standart greeding wav file). I dont know how to collect the wav file. is there any way to collect this wav file.
My aim is that to collect the english and turkish standart wav as a one wav. caller will hear english greeting first than turkish greeting.
java
java
There would be any web sites or locations to get the stndart greeting. Thanks for your response Jaime. BUt ı guess there would be any place to get this. Maybe using winscp to get ı guess .
is there any cli command to obtain standart greeding wav. fro CLI on unity connection?
Vadym
I ll open a case to cisco to obtain the related wav. hope ı will
