07-28-2014 08:10 AM - edited 03-16-2019 11:32 PM
I am just trying to grab serial number from CUCM 8.6 , but unable to get information of cisco 3905.
i can able find out for higher model from 7X & 8X.
Kindly help me to grab serial number.
Created instead of blog https://supportforums.cisco.com/blog/12265406/how-grab-serial-number-cisco-3905-cucm-86 as blogs are not used to post questions.
07-28-2014 08:21 AM
CUCM doesn't get the SN from the phones, you would need a 3rd party app to do this.
07-28-2014 09:09 AM
You can use 3rd party "Serial Grabber" appl to fetch serial numbers, Its easy to go with it.
Suresh
07-28-2014 10:49 PM
Hi Suresh,
I have already used serial Grabber for this. Serial grabber is unable to fetch 3905 phones serial no.
Can you suggest any other application for this.
Thanks & Regards
Harshali Nirgun
07-29-2014 12:15 AM
Hi Nirgun,
Please try to use (Phone Inventory App) from below link (just click download) and try.
http://www.voipintegration.com/Software/Download/Default.aspx?Product=PI11
Suresh
08-06-2014 07:55 AM
I have the same problem as creator of this topic. I need to find phones on my network but I have only theis serial numbers. I did downloaded Serial Grabber but it`s not working :( I`ve typed ip addressess from - to and after scanning I saved html file but only information was grand total: 1.
