Highlighted
Beginner
How to identify the cause of this Bus Error?
Our 3945E constantly crashes with an error similar to:
System returned to ROM by bus error at PC 0x636B2C2, address 0x636B2C2
The address corresponds to the main:text region according to the output of show region.
The only way we can avoid any crashing is by using version 12.2(8r)T2, RELEASE SOFTWARE (fc1). Any other release won't work. We could keep using this release, but it has a problem that we want to avoid but we can't update.
How can I debug this further? Is there anything that I can turn or to get something similar to an stacktrace so that I can pinpoint what was the last command executed before the crash?
thanks in advance
4 REPLIES 4
Highlighted
Hall of Fame Community Legend
If your router has crashed, then there could be a crashinfo file.  If there are files, post the last three.
Highlighted
Leo,
I will look into the crashinfo file and post it.
Meanwhile, we just enabled the feature to dump to ftp after crash. I'm attaching that file.
Thanks for your help.
Highlighted
Here goes the crashinfo file.
Highlighted
That is NOT your IOS.  That's the Bootstrap.  No wonder I was getting confused.
15.3(2)T
This is the IOS you are using.
And based on the crashinfo, you are hitting memory allocation errors.  Basically the router is "borrowing" the memory but doesn't know how to return the un-used memory back into the pool.  So the router keeps on borrowing until the memory runs out.
I'd recommend you either raise a TAC Case or upgrade the IOS and try again.
Content for Community-Ad
