Highlighted
Beginner
How to import CDR data from CUCM 9.1.2 to SQL Server 2008?
Hi Guys,
I've done to transfer CDR data to another server (billing server) by using sftp. Now I would like to know how to import these files to SQL Server 2008.
Please advise and appreciate your help.
Tan
3 REPLIES 3
Highlighted
Engager
CDRs are just CSVs, so you need to go ask in a SQL Server forum on how to do this.
NOTE: The CDR format tends to gain fields between CUCM versions (even minor versions) so you should make sure your import process can handle extra/unexpected fields.
GTG
Please rate all helpful posts.
Highlighted
CDR is flat file and no extension, do you know what's best third party software for this?
regards,
Tan
Highlighted
Variphy has a great CDR solution. There are others out there as well but that was my preferred vendor after looking at other solutions.
Content for Community-Ad
