ā11-08-2015 12:42 PM - edited ā03-18-2019 11:42 AM
Hi everybody,
I'm working on a CUCM 7 cluster of 7 servers.
I have to install .sgn file for the cisco 8831 phone model. To do so I've found a procedure on the internet and it worked before on one server.
My question is: should I install the .sgn file on each node of the CUCM cluster or only on the Publisher server ?
Thanks in advance, guys.
ā11-08-2015 01:18 PM
Hi Amine.
You should install it on all nodes and restart tftp server to make sure that it will be available for that phone model
Carlo
ā11-08-2015 01:50 PM
Thank you, Carlo, for the answer.
I got two TFTP servers, I assume that I should restart both of them.
ā11-08-2015 02:01 PM
Correct, you have to restart both.
This because some phones could be configured to point to one and other phone to the other server.
Thanks for nice rating
Carlo
ā11-08-2015 07:06 PM
If a device pack is installed to add support for a new device then the device pack needs to be installed on all servers followed by a cluster reboot. For any other device pack or firmware file install you need to install it on all nodes followed by a tftp service restart.
Manish
