04-25-2017 05:32 PM - modifié 03-17-2019 10:09 AM
On CUCM System version: 9.1.2.11900-12
I have a site with 10 phones. One phone is registering to the wrong node (subscriber).
The primary node is specified in the xml file on the TFTP server, isn't it? How do I change this? I've wondered this a million times. Is that setting in CUCM somewhere? What about phones that auto-register, or if a user brings a phone from the New York office to Chicago? What node comes up?
Does the Device Pool have something to do with it, or the Call Manager Group? If I go to Device>>Phone and search for it, I see the rogue phone registered to the wrong node. I don't have physical access, only remote to a jumpbox.
I think I remember seeing some page in CUCM that had the MAC listed and the firmware load. That would seem like a good place.
How do I change the node that a phone registers to?
thank you
Résolu ! Accéder à la solution.
le 04-26-2017 10:06 PM
If all phones are assigned to same DP which has one CUCM Server Group then they all should register to same node. I am assuming that this single CUCM Server Group has the right order (Sub-2 next Sub-1).
Assuming what I said is correct, then you don't need to edit the XML file. If this is 7900 phone, try to reset network settings by hitting the sequence settings > **# > More > Erase
If this didn't work, try to factory default the phone by disconnection the power cable > hold the # button > while the button is held power-on the phone > keep holding it until the speaker button starts flashing > release # button and hit 123456789*0#.
During phone registration after factory default make sure that phone firmware being loaded successfully.
These should fix your problem.
On a side note, editing XML file and uploading it won't help because everytime TFTP server restarts or you apply new setting to phone by hitting 'Apply Config' a new xml file will be generated which will override your custom file.
The tftp files can be viewed and downloaded by navigating to http://<ip address oftftp>:6970/
le 04-25-2017 05:57 PM
The CUCM group is what defines to what servers the phone will attempt to register to, in the order in which they're configured.
If it auto-registers, it gets the DP from the device defaults, or the one from the universal device template.
le 04-26-2017 04:06 PM
Hi Jaime,
But how do I make a phone register to a different node?
It's registering to sub-1. I want it to register to sub-2.
There is an XML file for every MAC, right?
The primary and secondary servers are in the XML, right?
The XML sits on the TFTP server, right?
What if I downloaded, edited, and re-uploaded that XML file so it said sub-2 and sub-2? That's a horrible solution, but would it work? Is the XML file editable in CUCM somewhere?
le 04-26-2017 04:08 PM
YOu will need to make sure the phone is assigned a call manager group with sub2 first then sub 1, create a device pool with this call manager group and assign that devicepool to the phone
Please rate if useful
le 04-27-2017 10:31 AM
Thank you Jaime and Dennis for helpful replies.
And Mohammed, your answer had everything I needed to know. Thanks.
Découvrez et enregistrez vos notes préférées. Revenez pour trouver les réponses d'experts, des guides étape par étape, des sujets récents et bien plus encore.
Êtes-vous nouveau ici? Commencez par ces conseils. Comment utiliser la communauté Guide pour les nouveaux membres
