How to make the AA via directly dial to internal extension
Kyaw Kyaw San
Dear Nipun Singh Raghav ,
I would like to directly dial the international extension after voice announcement or press"0" to perator.
Do I need to modify the TCL script file for dial the internal extension.I cant find the way how to make it.Please kindly instruct how to do it.
R0g22
Yes, you would need to edit the TCL script to accomplish that. You can post your query over at DevNet support forums.
6 Replies 6
R0g22
Dear Nipun Singh Raghav,
Now the AA service working well according to your instruction.But I can't see the caller-ID number of caller who pass via the AA service.When I enable the caller ID on PSTN port,the AA service does not work.Why it happen like that?Could you help to fix this issue.
For another PSTN port,when I call the PSTN number of that port go and fall into AA service though that doesn't run AA service but caller-ID enable.When I disable the caller-ID off ,it directly go to the associated extension.You may kindly check the config script below.
voice-port 0/1/0
 trunk-group PSTN
 description 3592390
voice-port 0/1/1
 trunk-group PSTN
 description 3592395
voice-port 0/1/2
 trunk-group PSTN
 description 3592392
voice-port 0/1/3
 trunk-group PSTN
 description 3592393
voice-port 0/2/0
 trunk-group PSTN
 description 3592394
voice-port 0/2/1
 connection plar opx 2012
 description 3592395_for_MGR
voice-port 0/2/2
 description 3592396-FAX
voice-port 0/2/3
 description null
dial-peer voice 100 pots
 service aa-test
 answer-address .
 port 0/1/0
dial-peer voice 101 pots
 service aa-test
 answer-address .
 port 0/1/1
dial-peer voice 102 pots
 service aa-test
 answer-address .
 port 0/1/2
dial-peer voice 103 pots
 service aa-test
 answer-address .
 port 0/1/3
dial-peer voice 104 pots
 service aa-test
 answer-address .
 port 0/2/0
Is this on the same ISR-4k ?
And also, post this as a new thread.
Yes same ISR4K.I dont know how do I post as a new thread.Please.
Just create a new post like you did for this one.
