How to manipulation of SIP headers on voicegateway?
Michael Endler
i facing an issue with jabber. My issue is coming from the voice gateway.
I get from the provider a SIP/2.0 100 Trying to the gateway. The Phonenumber get sent to the callmanager via SIP/2.0 183 Session Progress.
May current thinking is the usage of voice class sip-profiles, can i use that like a translation-rule?
How can i change the incoming Remote-Party-ID-field + Contact -field in the sip header?
voice class sip-profiles 500
request INVITE sip-header P-Asserted-Identity modify "<sip:(.*)@(.*)>" "<sip:00496925771065@192.168.50.48>"
request INVITE sip-header P-Asserted-Identity add "P-Asserted-Identity: <sip:00496925771065@192.168.50.48>"
request INVITE sip-header Remote-Party-ID modify "<sip:(.*)@(.*)>" "<sip:00496925771065@192.168.50.48>"
Debugs:
6175365: Feb  2 17:58:00.412: //1315268/2AB9E1800000/SIP/Msg/ccsipDisplayMsg:
    Sent:
    SIP/2.0 100 Trying
    Via: SIP/2.0/TCP 192.168.50.53:5060;branch=z9hG4bK130a9371280707
    From: "Test IT-DS" <sip:1065@192.168.50.53>;tag=9230525~8f30a84d-ce6a-4ef2-86e4-7e1d4e6fe6fc-40971876
    To: <sip:005123520542@192.168.50.59>
    Date: Sun, 02 Feb 2014 16:58:00 GMT
    Call-ID: 2ab9e180-2ee17918-113bf8-35401bac@192.168.50.53
    CSeq: 101 INVITE
    Allow-Events: telephone-event
    Server: Cisco-SIPGateway/IOS-15.2.2.T2
    Content-Length: 0
    6175373: Feb  2 17:58:00.412: //1315268/2AB9E1800000/CCAPI/cc_api_display_ie_subfields:
       ccCallSetupRequest:
       cisco-username=1065
       ----- ccCallInfo IE subfields -----
       cisco-ani=00496925771065
       dest=00495123520542
    6175398: Feb  2 17:58:00.416: //1315269/000000000000/SIP/Info/ccsip_get_int_type_frm_set_mode_ev:
    SIP/2.0 100 Trying
    Via: SIP/2.0/UDP 192.168.50.59:5060;branch=z9hG4bK176B16173E
    From: "Test IT-DS" <sip:00496925771065@192.168.50.59>;tag=3BABBE1C-319
    To: <sip:00495123520542@82.211.220.200>;tag=gK02dcc866
    Call-ID: 1C7A118-8B6211E3-AB6BF30F-EC3C4587@192.168.50.59
    CSeq: 101 INVITE
    Timestamp: 1391360280
    Content-Length: 0
    6175768: Feb  2 17:58:04.240: //1315268/2AB9E1800000/SIP/Msg/ccsipDisplayMsg:
    Sent:
    To: <sip:005123520542@192.168.50.59>;tag=3BABCD0C-634
    CSeq: 101 INVITE
    Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
    Remote-Party-ID: <ip:00495123520542@192.168.50.59>;party=called;screen=no;privacy=off
    Contact: <sip:00495123520542@192.168.50.59:5060;transport=tcp>
Manish Prasad
Level 5
Level 5
Hi Michael,
May current thinking is the usage of voice class sip-profiles, can i use that like a translation-rule? - Yes you can use this feature in SIP profile modify to match a set of header and replace with other.
How can i change the incoming Remote-Party-ID-field + Contact -field in the sip header? - Sip pofile works only for outgoing messages not for incoming , for this you need to look at SIP normalization script to achieve this.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/sip_tn/8_5_1/9-script_param.html
Rate all the helpful post.
Manish
Manish Prasad
Level 5
Level 5
Hi Michael,
Manish
Hello Manish,
thank you for the quick answer, which seems to be correct. It looks like this is not done by a simple, additional parameter on the voicegateway.
I think this is again a thing what cisco should fullfill -> manipulation in both directions
Can i change the mandatory fields on callmanager, when incoming ?
Michael
i managed to modify the session progress sip header:
Regards Michael
voice class sip-profiles 800
response 183 sip-header TO copy "<>
response 183 sip-header Remote-Party-ID modify "<>
This is the new feature (copy) available with cube in 15.1(x) ios. Which i recently get to know from one of post in CSE.
Glad that you managed to achive it.
Manish
