03-31-2015 08:40 PM - last edited on 03-25-2019 08:34 PM by ciscomoderator
Hi Team,
I have cisco 2951 router with CUBE& UC License and its UP & running. Now we have planing to upgrade the router from Cisco 2900 to 3900.How to migrate the both licenses and upload the new router. How to verify.
Please share the step by step procedure
Thanks & Regards,
Johnson.
Solved! Go to Solution.
03-31-2015 10:44 PM
Hi Mate,
Refer to below instructions for hosting licenses on ISRs:
http://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/software-activation-on-integrated-services-routers-isr/white_paper_c11_556985.html#wp9001047
Rehosting a License
Prerequisites:
• Valid Cisco.com account (username/password)
• Retrieve Product Id and Serial Number with either the IOS "show license udi" command or label tray from both the source and destination devices.
• Retrieve Source Device Credentials by issue the following IOS commands in exec mode:
– license save credential flash0:CredentialFileName
– more flash0:CredentialFileName
• The source device has rehostable licenses.
Rehosting a License with Cisco's Licensing Portal
This process can be used when the source and the destination device cannot communicate directly with Cisco licensing portal
Summary Steps:
1. Obtain UDI and device credentials from the source and destination devices using IOS CLI commands
2. Contact the Product License Registration page on Cisco.com and enter the source Device Credentials and UDI into the license transfer portal tool.
3. The portal will display licenses that can be transferred from the source device.
4. Select the licenses that need to be transferred. A permission ticked is issued. You can use this permission ticket to start the rehost process using Cisco IOS c for any further help.ommands.
5. Apply the permissions ticket to the source device using the license revoke command. The source device will then provide a rehost ticket indicating proof of revocation. A sixty day grace period license is also installed on the device to allow enough time to transfer the licenses to destination device.
6. Enter the rehost ticket into the license transfer portal tool on Cisco.com along with destination device UDI.
7. Receive the license key via E-mail
8. Install the license key on the destination device.
You can also email licensing@cisco.com
-Terry
Please rate all helpful posts
03-31-2015 10:44 PM
Hi Mate,
Rehosting a License
Prerequisites:
Summary Steps:
-Terry
03-31-2015 10:50 PM
As mentioned above you can also reach out cisco licensing team for assistance as well by emailing them: licensing@cisco.com
Once done you can verify the licenses using commands like: show license details, show license feature.
-Terry
