06-07-2018 02:15 AM - edited 03-17-2019 12:58 PM
Solved! Go to Solution.
06-18-2018 03:42 AM
hi again!
well I could not export and import configs from 7.1.5 to 8.6.2 because of a huge amount of errors.
now I try to understand how I can upgrade my test CUCM 7.1.5 to 8.6.2
I tried to start the VM with 7.1.5 from the connected virtual DVD with bootable 8.6.2.
but it asks "do you want to rewrite the disk?"
and it's not what I want to do.
what is the right way of uprgrading from 7.1.5 to 8.6.2?
06-18-2018 03:59 AM
To upgrade on the same hardware, you do not boot from disk. The simplest way for you to proceed would be to insert the disk when CUCM is running, browse to CUCM OS Administration and navigate to Software Upgrades > Install/Upgrade.
There are several ways of performing the upgrade and recommend you review the below before proceeding.
MonCov
07-05-2018 02:15 AM
Thanks a lot, colleagues!
I was able to migrate with the help of intermediate CUCM 7.1.5 which was upgraded to 8.6.2 and so on...
The advice to migrate by moving configs did not help.
Now I try to re-host the license which became invalid after the last DRS restore on the working CUCM 8.6.2
but it is not the question of this thread :)
