04-06-2020 10:57 AM
hi,
We have 120 Phone Template to move from UCM 11.5 to 12.5.
Is there any idea how to do easily and quick ? BAT does not seem to have option for it.
tks,
K
04-07-2020 08:13 AM
BAT does have this available under Import/Export - Export. Then under Device Data choose Phone Button Template. Run the export then save the tar file from Upload/Download Files and you will have the csv for your templates that you can then import to 12.5.
04-07-2020 08:45 AM
Phone template is not Phone "Button" Template, I don't see in BAT.
7945 model has Phone template
7921 model has its own Phone template
04-07-2020 09:33 AM
Unfortunately there is no way to export the Phone Templates from CUCM that I am aware of.
