05-04-2017 06:02 AM - edited 03-17-2019 10:14 AM
Is it any way in CUCM 11.0.1 to play an announcement "your call is being recorded" for called party in the beginning of the outgoing call from our office?
05-04-2017 06:16 AM
Hi Victor,
Within CUCM there is no such native option to play such an announcement to called party, you MAY however be able to get it to work with UCCX based on the call flow and how the script is programmed.
Manish
05-12-2017 02:52 PM
You would need someone to write a TCL script to play as the call goes in or out from the voice gateway.
05-13-2017 10:17 AM
Hello Victor,
You can use the below third party recording solution for such scenarios.
Such features are not provided from CUCM itself and has to be from third party.
https://www.miarec.com/book/export/html/780
Also check from Imagicle recording solution if they provide the same feature.
Raaj
