How to play ringtone on cisco ip phone programmatically?
mahmoud.saleh
i am running a timertask to check for new emails, and if there are new emails play default ringtone on the ip phone, so i was wondering how to play default ringtone on cisco ip phone programmatically from java code, not from jsp page.
please advise, thanks.
Gordon Ross
Level 9
Level 9
I can see two ways of doing this. Daft as it may sound, the simplest way is just to get your program to make a phone call !
The other way is to use a variety of the CallManager APIs. The developer web site is your friend here:
http://developer.cisco.com/web/cdc/tech/ucvoice
You'll need to use several of the API sets:
- IP Phone Services to play an audio stream. (You can't just play a WAV file on a phone - well you can, but there are limits on it.)
- RIS to get the IP Address of a device
- AXL to get the device name from a phone number.
GTG
Please rate all helpful posts.
