12-04-2012 04:58 AM - edited 03-16-2019 02:32 PM
I have to prepare a BOQ for Upgration CUCM from 7.x to latest version.Please tell me the part number or and anything that is required to add in BOQ.
Thanks n Regard,
Waqas
Solved! Go to Solution.
12-04-2012 06:02 AM
These forums are targeted for technical support, not presales assistance. You can use the ordering guides or engage the partner helpline, PDI HD, or your local Cisco Channel SE.
12-04-2012 06:44 AM
Just a clarification on the above, we do not assist on such matters:
http://www.cisco.com/web/partners/tools/pdihd_faqs.html#services_other
Presales assistance is what you need
www.cisco.com/go/ph
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
12-04-2012 06:02 AM
12-04-2012 06:44 AM
www.cisco.com/go/ph
java
