How to query phones by ActiveLoadID
Iyad Musleh
I 'm looking for a way to list/export all Cisco phones along with their ActiveLoadID. We're running on CUCM 8.5.1.  I've looked into Bulk Administration, but that only gives me what's in the Phone Load Name field.  I've used RTMT-->CallManager-->Device Search and, while it does show the ActiveLoadID, it only shows the first 200 devices with no option to see the remaining devices. (I have about 2,000 devices).  Anyone have any other ideas on how to get the ActiveLoadID?
Deepak Rawat
You can run show risdb query phone on all the CM servers in the cluster to which phones are registered and then sort out the output in MS Excel and find the active FW load
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified...
Deepak
Deepak Rawat
Deepak
Iyad Musleh
That did the trick. . . Thanks Deepak!
Glad that it helped Iyad and thanks for marking the Correct Answer.
Deepak
gls47897FE
Running the show risdb query phone command on Subscribers with registered telephones works as designed. Thank you.
