How to reach SRST ip phones from Central CallManager site
a.shaik
I have one central site where I have Two Callmanagers in release 6. And I have several small sites where SRST will be deployed.
All phones are configured with Extension Mobility.
My problem is the following. When wan is down, I configured SRST gateway to call correctly central site Ip phones via transalation rules. But, I didn't succeded to route calls from central site to SRST sites. I try to use Forward Unregistered Internal and External with correct number via PSTN, but it's not working. I think it's because of device profile where extension mobility resides. Device profile nevers unregister. Any solution will be greateful.
iptuser55
Level 6
Level 6
That should work but with EM you have problems. The CFNR number needs to the persons DDI at the remote site, user at the remote site has a DDI which terminates on a router at the remote site, as far as SRST, Call Manager is aware the logged in person is just unregistered so call from HQ will use the CFNR setting - DDI of the remote person and route the call out
