06-09-2013 11:33 PM - edited 03-16-2019 05:46 PM
Hi Guys,
Can anyone of you help me to understand if is there any way to record a inboind/outbound call in CUCM without exploring UCCX. is there any inbuild component available in CUCM or Unity connection which can used for recording call or the only way to use a thitd party tool (like, NICE, MiaRec, VPI) or to deploy UCCX to accokplish this.
06-09-2013 11:51 PM
You need to buy a recording solution available from various vendors. You can search the forum for more information.
06-10-2013 08:28 AM
CUCM only provides assistance for the 3rd party product or UCCE/UCCX in regards to the configuration of the BIB from phones so it sends the stream to the recording appliance, and... that's it.
CUCM is a call control appliance, not a recording server.
You can use CUC, but it's a manual process which needs to be triggered by the user, who is basically conferencing CUC to record each call.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
07-20-2013 02:55 AM
You need third party recording solution
regards
Mohamed
