How to Remove "Wait i Transfer your call" in Unity Connection
harisivaji
Beginner
Beginner
We have to transfer the  call from a Call Handler to Non VoiceMail user extension to CUCM.
Based on the Caller Input (Transfered to Alternate contact no), call will be routed to CUCM. We would like to remove the message
"Wait i Transfer your call" which is being played before the transfered number starts ringing
Note: If the Transfered number is known to CUC, means extension configured as Voice Mail extension then this is not played, but the transfered number is non voicemail user.
I beleive the "Transfer rule" section where the check box ;
Play the "Wait While I Transfer Your Call" Prompt
is not related to this since, since the call is not transfered as per the Transfer rule configuration, as it is transfered out of the CH based on caller input
Also, we tested by unchecking the same, but it didnt help
Hari
5 Replies 5
harisivaji
Beginner
Beginner
Any Solution
What I can think of is to transfer this in a different way..
Create a new CH eh CHNEW
On the caller iput set this to transfer to CHNEW, click on attempt transfer
Then go to the CHNEW, edit the transfer rules, set it to transfer call to extension..Then put the extension you want there..set transfer type to release to switch and then uncheck play wait while I trabsfer your calls
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Thanks for your Help, But we do have Multiple options on the Main Menu, and there are sub menu with more options so for each caller input there will more extension
This has been asked many times and there is no way to do it..However there is an un supported way to do it..Read this thread. The only clean way to do it is what I have suggested. Jeff lindborg is the guy who developed Unity connection software, so if he says it cant be done then it cant.
https://supportforums.cisco.com/thread/288432
lephudanh
Beginner
Beginner
Who anyone help us remove "wait I transfer your call? ?
