How to remove red led from Ipphone cisco 8851
juan.mejia
I have delete voice message from my iphone but the red light does not turn off.
Some one knows why?
Regards.
9 Replies 9
Ratheesh Kumar
Try doing a resync of MWI from telephony Integration > Phone system
Cheers
Rath!
***Please rate helpful posts***
hi
doing a:
I finded the way to do it but i not sure if there is any risk for my system when i apply the funcction.
And  i need to do it in the subscriber?
Regards.
Hi there
Synchronizing MWIs for the phone system may affect system performance. We recommend that you do this task when phone traffic is light.
To Synchronize MWIs for a Phone System Integration
Step 1 In Cisco Unity Connection Administration, expand Telephony Integrations and select Phone System. On the Search Phone Systems page, select the name of the phone system for which you want to synchronize all MWIs.
Step 2 On the Phone System Basics page, under Message Waiting Indicators, select Run .
Cheers
Rath!
Jaime Valencia
What do you use for voicemail?
java
if this helps, please rate
Cisco Unity Connection version: 10.5.2.12901-1.
You can also reset the MWI on a single voicemail box by going into Unity Connection into the user's account. access the Message Waiting Indicators menu item in the user's account, checking the box for the MWI and clicking "Reset All".
Hi, I did all but there's no changes in the phones maybe it's same something else well thanks any way.
Regards.
Is your voicemail intergration sccp or sip?
If sip ensure that your trunk has a css that will allow access to the dn partition.
What is your MWI OFF number? can you dial the MWI OFF number from the phone affected?
Saiful Islam
