02-08-2011 08:43 PM - edited 03-16-2019 03:20 AM
Hi All,
Can some one help me to know the factry default steps for IP Phone 3911
Asif
02-09-2011 12:12 AM
For CME
The default password for phones registered to CME is "Cisco" (with capital C).
Can you edit phone's cnf file? If yes, you can and these thing in it:cisco
For CUCM
If the password "cisco" didn't work, you can set a new password in CCM: CCM Admin -> Device -> Device Setting -> Common Device Configuration -> Local Phone Unlock Password. You have to reboot 3911 after that. Note that, If 3911 is using a customized "Common Phone Profile", then you have to modify corresponding one.
02-09-2011 05:55 AM
Thnks for the respose.
Its a new phone. What happened is, it connected to network and registered with callmanager once. Then we have removed the device and connected to user desk but it is not working (keep on restarting). Which was repeating for all new phone which am configuring (My network already running with same 3911 model phone).
Finally what I found is, new conneting phones are working fine after down grading the firmware from SIP3951.8-1-4a to SIP3951.8-1-2SR1.
But the phone which I have registered first (SIP3951.8-1-4a) are keep on restarting and not registering even after changing the device default (phone loadname also) to SIP3951.8-1-2SR1.
Asif
03-07-2013 08:18 PM
Did you find the solution for the issue. We are running into the same issue and not sure about the resolution.
03-13-2014 04:26 AM
Hello, has anyone come up with a solution on how to resolve this issue?
08-25-2015 10:50 AM
Just had same issue. Remove the switchport voice vlan and the phone will recover enough to access settings if needed
03-14-2018 06:09 AM
Can anybody tell me how to downgrade firmware of cisco 3911 from tftp?
