how to reset the CUE GUI credntial
Hi Team,
I am trying to login to cue gui but not able to login. i am putting the correct credential but login is getting fail.
username: admin
password: B@ck0FF!
is tehre any way to reset the password with same credential. I mean i dont want to change password . Want to put B@ck0FF! only.
Vaijanath Sonvane
What version of CUE you are using and what is the router mode?
Have you tried the process mentioned in below URL:
https://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unity-express/64234-cue-gui-pw.html
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Vaijanath Sonvane
Thanks Much Sir. It solved the problem.
Appreciated!!!!
